Go Back   Mac Club Indonesia : Macintosh - Ipod - Iphone > Mac Club Forums > Games
Games Software-software permainan di Macintosh
Reply
Thread Tools Display Modes
  #1
Old 11-09-2008, 23:18
iomegaz iomegaz is offline
Anggota Baru
Default [RS.com] Counter Strike Source V1 (Cider Port)
Click the image to open in full size.
:O>>Click the image to open in full size.<< :O
Hi, today i post Counter Strike Source Version 1.
Why version 1?
Because it's a version which works on Internet, but not totally.
You can't see all Non-Steam servers and can't play on them.
Take-it and test, it's a great game. Works great.
In the version 2, you will can play entirely on Non-Steam servers.
Note: this version support GMA card (i'm not sure...)
If you have an error occured by a Windows Library or Other, select only the graphics marked by a * on the Setup.
If the game has problem again, read the Readme.rtf file
If your mouse cursor doesn't work on the menu, use the Keyboard.
Join with Split&Concat
Copy the game to your Apps folder
Thanks to MrBeru and Xerxes9000sx for their works
Bye and good download
Code:
http://rapidshare.com/files/147648858/CSSource_Mac_Version_1.zip.012
http://rapidshare.com/files/147651602/CSSource_Mac_Version_1.zip.011
http://rapidshare.com/files/147654657/CSSource_Mac_Version_1.zip.010
http://rapidshare.com/files/147657563/CSSource_Mac_Version_1.zip.009
http://rapidshare.com/files/147660407/CSSource_Mac_Version_1.zip.008
http://rapidshare.com/files/147663176/CSSource_Mac_Version_1.zip.007
http://rapidshare.com/files/147666010/CSSource_Mac_Version_1.zip.006
http://rapidshare.com/files/147668903/CSSource_Mac_Version_1.zip.005
http://rapidshare.com/files/147641495/CSSource_Mac_Version_1.zip.004
http://rapidshare.com/files/147643980/CSSource_Mac_Version_1.zip.003
http://rapidshare.com/files/147646716/CSSource_Mac_Version_1.zip.002
http://rapidshare.com/files/147825210/CSSource_Mac_Version_1.zip.001
  #2
Old 11-10-2008, 02:30
didit_aconk's Avatar
didit_aconk didit_aconk is offline
Mac Pro 8-core
Images: 1
Default
izin sedot ya bro...hehehhehe
__________________
MANTAN SAY NO TO I.K.E.T. Member
I'M A PUNK
  #3
Old 11-13-2008, 22:14
Johny-SPIN Johny-SPIN is offline
Anggota Baru
Default
  #4
Old 12-04-2008, 22:00
Anggota Baru
Default Help meee please!!!
Hello boys, I have a problem. I dowloaded CS:Source. I joined it with SPLIT&Concat,then my problem began. I cannot extract archive. When I use builtin archiver to extract it, the result is the same archive but with *.zip.cpgz. Okej I tryed to extract also this *.zip.cpgz file, but it is magic circle!!
Have the same problem with NFS MW...
Every advice will be welcome. THANKS
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Design By: Miner Skinz.com
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2002-2009, MacClubIndonesia.Com
