Results 1 to 4 of 4
  1. #1
    Join Date
    May 2009
    Location
    Kemayoran, Jak-Pus
    Posts
    935
    Default Cara Setting GPRS dan MMS
    cuma mau sekedar berbagi...
    sorry yah klo
    1.
    Be sure that you removed all previous MMS & Tethering Hacks/Profiles if you have any installed. If you have a previous installed MMS & Tethering Settings Hack installed from the SiNfuL iPhone Repo then read below on "How to UPGRADE".
    2.
    Open Cydia/Icy and make sure that you have http://www.sinfuliphonerepo.com added to your sources.
    3.
    Now tap on the Sections tab and goto the SiNfuL iPhone section.
    * If your using a 2G iPhone then you need to either install the package called Enable MMS for 2G & 3.0 FW -OR- Enable MMS for 2G & 3..1.2 FW depending on which FW you are running on your phone. If you are running FW 3.0.1 on your phone then you can just install the package called Enable MMS for 2G & 3.0 FW. Both of these packages will automatically install the MMS & Tethering Settings package as well if you don't already have it installed. This is to update your carrier settings so that everything will work properly.
    * If your using an iPhone 3G or 3GS then you only need to install the MMS & Tethering Settings package.
    4.
    After you have installed the correct package/packages for your phone, (You will have to REBOOT if your using an iPhone 2G) exit out of Cydia/Icy and goto Settings -> General -> Reset and tap on Reset Network Settings This will flush out all your old settings and ensure that the new settings overwrite any old ones. Make sure you do this on the iPhone 2G as well.
    5.
    After your phone reboots now goto Settings -> General -> Network -> Cellular Data Network and scroll down and tap on Reset Settings. Also at this point you can change any of the APN settings if you need to. For example you might want to use wap.voicestream.com or internet2.voicestream.com for your Cellular Data APN instead of epc.tmobile.com
    6.
    If you need to change any of the settings you should reboot your phone so that the new settings will take effect.
    7.
    After you reboot your phone you can go into Messages and tap on the create new message icon and you will now have a camera icon across from your send button just like the picture below
    kalo uda selesai..
    isi apn, username, passd dll..
    MATRIX
    Setting OTA:
    Kirim SMS ke888 dengan pesan :
    ACT[spasi]GPRS
    MENTARI
    Setting OTA via SMS ;
    Kirim SMS ke3000 dengan pesan :
    Ketik : GPRS[spasi] merk HP[spasi] tipe HP
    Setting Manual :
    GPRS
    APN : indosatgprs
    username : indosat
    password : indosat
    MMS
    APN : indosatmms
    Username : indosat
    Password : indosat
    MMSC : http://mmsc.indosat.com
    MMS Proxy : 10.19.19.19:8080
    MMS max msg sz : 614400
    MMS UA Prof URL : http://wap.klub-mentari.com
    IM3
    Kirim SMS ke3939 dengan pesan :
    Setting Manual :
    GPRS
    APN : www.indosat-m3.net
    username : gprs
    password : im3
    MMS
    APN : indosatmms
    Username : indosatmms
    Password : indosatmms
    MMSC : http://mmsc.indosat-m3.net
    MMS Proxy : 010.019.019.019
    MMS UA Prof URL : http://wap.indosat-m3.net
    TELKOMSEL
    KARTU HALLO
    Kirim SMS ke 6616 dengan pesan :
    Ketik : GPRS
    KARTU SIMPATI/KARTU AS
    Ketik : GPRS[spasi]angka dibelakang simcard Anda (Nomor ICCID/Integrated Circuit Card Identification)
    Kemudian tunggu beberapa saat, Anda akan mendapat SMS konfirmasi bahwa aplikasi GPRS sedang diproses. Waktu yang dibutuhkan sekitar 48 jam. Setelah GPRS aktif, Anda akan mendapat notifikasi SMS lagi yang menyatakan GPRS sudah aktif.
    Setting Manual :
    GPRS
    APN : telkomsel
    username : wap
    password : wap123
    MMS
    APN : mms
    Username : wap
    Password : wap123
    MMSC : http://mms.telkomsel.com
    MMS Proxy : 10.1.89.150
    MMS UA Prof URL : http://wap.telkomsel.com
    XL
    Ketik SMS dengan isi : GPRS[spasi][spasi] Kirim ke 9667
    Ketik SMS dengan isi : MMS[spasi][spasi] Kirin ke 9667
    Setting Manual :
    GPRS
    APN : www.xlgprs.net
    username : xlgprs
    password : proxl
    MMS
    APN : www.xlmms.net
    Username : xlgprs
    Password : proxl
    MMSC : http://mmc.xl.net.id/servlets/mms
    MMS Proxy : 202.152.240.050
    MMS UA Prof URL : http://wap.lifeinhand.com
    3 (three)
    GPRS
    APN : 3gprs
    username : 3gprs
    password : 3gprs
    MMS
    APN : 3mms
    Username : 3mms
    Password : 3mms
    MMSC : http://mms.hutch.co.id
    MMS Proxy : 10.4.0.10
    MMS UA Prof URL : http://wap.three.co.id
    KARTU AXIS
    GPRS
    APN : AXIS
    username : AXIS
    password : AXIS
    MMS
    APN : AXISmms
    Username : AXIS
    Password : 123456
    MMSC : http://mmsc.AXIS
    MMS Proxy : 10.8.3.8
    MMS UA Prof URL : http://wap.axisworld.co.id
    semoga bermanfaat
    CMIIW
    iPhone4 32Gb black FU 5.1.1 Jailbroken
    iPad1 wifi 16Gb 5.0.1 Jailbroken
    Macbook White 10.7.4
    Blackberry 9780 black
  2. #2
    Join Date
    Jul 2007
    Location
    South Borneo
    Posts
    302
    Default
    Bedanya sama yg di sini apa bro??
    A p p l e F r e a k
  3. #3
    Join Date
    May 2009
    Location
    Kemayoran, Jak-Pus
    Posts
    935
    Default
    Quote Originally Posted by amank View Post
    wakz....
    sama yah....
    tp klo yg g punya kan ada cara enable mmsnya... (alasan) :001_tt2:
    sorry om momod........ :001_tt2:
  4. #4
    Join Date
    Aug 2005
    Location
    Depok-Bogor
    Posts
    7,837
    Default
    udah pernah juga dibahas tentang reponya sinfuL.... setingan MMS sinfuL yg selalu berubah...
    yang pasti ini thread repost.....
    ..:::.. UNIX GEEKS ..:::..
    bugemac's hashes MD5, SHA1, CRC32
    md5 : 37fdde472d860d072ba48c5316aa33cb
    sha1 : 55a7f80051de2e5fe8dc84192dee57e336ac627c
    crc32 : 353534171
    http://www.macclubindonesia.com/forums/image.php?type=sigpic&userid=587&dateline=12475278  25
    myTwitter : @BudimanRubiaV
Similar Threads
  1. [help] ga bisa setting gprs
    By zhan13 in forum Semua tentang iPhone
    Last Post: 08-10-2009, 18:47
  2. Cara setting Little Snitch buat iPhone ...
    By taz_79 in forum Semua tentang iPhone
    Last Post: 03-07-2009, 11:18
  3. HELP & ASK: cara setting samsung sgh-z170 di ibook G4
    By jinggana in forum Internet di Macintosh
    Last Post: 15-09-2008, 04:47
  4. <ASK> Setting cara terima telp
    By Alvonsso in forum Semua tentang iPhone
    Last Post: 08-09-2008, 21:01
  5. Ask : cara setting wi-fi at home
    By dfnkid in forum Internet di Macintosh
    Last Post: 03-01-2008, 21:25
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
