Page 1 of 38 12311 ... LastLast
Results 1 to 10 of 374
  1. #1
    Default (JUAL) Apple/Iphone/Ipod Product Accesories, battery, earphone, car holder etc
    One Stop Shopping Iphone, Ipod, Gadget, part & Accessories
    1A. 100% Original Earphone Headphone With Mic for Apple iPhone
    minta harga Rp.175.000/pc
    kalo minat silahkan PM, Call/sms 081314157977
    atau email matsubi2000@gmail.com dan ym: matsubione@yahoo.com <--- Push notification support
    Iphone Ping ID : erfan
    Description:
    100% Original Apple Earphone , Brand New.
    High quality Hands-Free Stereo Headset w/ microphone for Apple iPhone .
    With one press (on the Mic) you can answer your call immediately (very convenient while you are listening to your favorite music) once the call hang up, your favorite music will come up again automatically and you don't need to touch anything.
    Can also toggle the Play or Pause for your music with a simple press on the On/Off button (you don't even need to touch any icon on the iPhone screen for this, very convenient right).
    Double press on the microphone, it will forward to the next song.
    Compatible with iPhone & iPhone 3G &all other 3.5mm devices
    Color: White
    The length of the line : about 1.1m
    1B. Genuine Apple Headphones with Remote for iPod Shuffle
    harga Rp. 195 ribu
    Description:
    Genuine Apple Headphones with Remote for iPod Shuffle 3rd
    Brand New OEM Package (Bulk Pack)
    Description
    Adjust the volume by pressing the + and - buttons.
    Control music and video playback . including play/pause and next/previous .
    Frequency response:5Hz to 21kHz
    Impedance (at 100Hz):twenty-three ohms
    Sensitivity (at 100Hz):109 dB SPL/mW
    This accessory is compatible with the following:
    iPod touch 2nd generation
    iPod classic 120GB 160GB (2009)
    iPod nano 5th generation (video camera)
    iPod nano 4th generation (video)
    iPod shuffle 3rd generation
    1C. 100% Brand new original iPod earphone.
    new and Original 100%
    harga Rp.100.000 saja, sudah termasuk ongkir
    This ORIGINAL Earphone is designed to work for Apple iPhone/iPod/Nano/Touch/Classic/Video, MP3 players, CD players, portable DVD players and other 3.5mm earphone jack compatible portable devices.
    2. Orignal USB Cable for Iphone Ipod
    Harga 100 rb
    silahkan kalo minat bisa hubungi
    | Contact |
    http://toko-gadget.com
    ym : matsubione@yahoo.com
    e-mail : matsubi2000@gmail.com
    call/sms : 081314157977 (iMessage , whatsapp, Viber Ready, LINE)
    PIN BB : 75B7D954
  2. #2
    Default
    3.B Apple USB Power Adapter / Charger for iPod / iPhone, 3G/S (Type B)
    Harga 200 ribu
    Genuine Apple USB Power Adapter for iPod iPhone
    NO FAKE!
    NO AFTER MARKET!
    No poor quality!
    4A. Iphone 3G/3GS Car Holder
    Car holder untuk Iphone 3G /3GS Type A
    harga Rp.150 rb, termasuk ongkir
    4B. Car holder untuk Iphone 3G /3GS Type B
    Brand new high quality car holder for iPhone 3G, 3GS
    4 C. Windscreen Car Mount Holder For Apple Iphone 3G S 3GS
    Harga 175 ribu
    6A. Charger & Hotsync Dock Cradle for Apple iPhone 3G iPod
    harga 150 rb
    * Brand new product with high quality
    * Small and light ,easy to take away
    * charge your iPhone and sync data
    * Elegant and compact designed white docking cradle, Perfect for your iPhone or iPod
    * You can connect the dock to your computer with with the cable that came with your iPhone, then place your iPhone in the Dock to sync and charge the battery
    * Also connect the Dock to an electrical outlet using a USB Power Adapter, so charge your the battery
    * Enjoy your music from iPhone by using a stereto audio cable to connet the dock to a stereto or speakers
    * Enganced Display photos or video on a TV or other video device using a Component AV Cable or Composite AV Cable
    Size: approx. 6.5 x 4.3 x 1.7 cm
    Audio interface: 3.5mm standard connector
    Applicable to: iPod Photo display
    iPod with Video (30GB/60GB/80GB)
    iPod Nano 3rd generation (4GB/8GB)
    iPod Nano 4th generation (8GB/16GB)
    iPod Classic (80GB/120GB/160GB)
    iPod Touch (8GB/16GB/32GB)
    iPod Touch 2nd generation (8GB/16GB/32GB)
    Apple iPhone (4GB/8GB/16GB)
    iPhone 3G (8GB/16GB)
  3. #3
    Default
    6B. iPhone 2G New Original Charger for Sync Dock Cradle
    Harga 175 ribu
    7 STYLUS TOUCH PEN FOR APPLE IPOD ITOUCH IPHONE 3G
    Harga Rp.30 ribu
    Product Introduction
    Specially designed for the iPhone and iTouch
    Clip design, easily clip in your pocket, book, diary, etc.
    It's sensitive to type or tap as so to work quickly and accurately.
    Length: 10 cm
    Best for typing not writing
    8 ORIGINAL APPLE CHARGER DOCK CRADLE FOR IPOD SHUFFLE 2 2ND 3 3RD GEN 2G
    harga rp.120 ribu
    . 100% new high quality Multi Function Cradle for Apple iPod Shuffle 2nd/3rd Generation
    . This docking station is a convenient & elegant home base cradle that will make syncing & charging easier than ever
    . This 2 in 1 cradle lets you transfer music and charge your 2nd/3rd generation shuffle simultaneously
    . Compact & solid design
    1.A (BNIB) Ipad 64 GB Wifi+3G
    kondisi Seal in Box
    Ipad 64 giga wifi+3g. Harga -- juta. ---ready stock ---
    The best way to experience the web, email, photos, and video. Hands down.
    spec :
    http://www.apple.com/ipad/specs/
    8.A. Original Ipad Case
    Brand New in BOX (seal)
    harga Rp. 550.000
  4. #4
    Default
    8.B Genuine Ipad Dock
    Harga 400 ribu
    8.C Apple iPad Camera Connection Kit
    Brand new
    Harga 650 ribu
    8D. MicroSim adapter for iPad 3G Convert Sim - Micro Sim
    Harga 75 Ribu
    Untuk pemakai Micro sim di Ipad/ Iphone 4, bisa menggunakan adapter ini untuk di gunakan di iphone/telephone dengan SIM Standard
    9. New Black Slim-fit leather Case Cover for Apple iPhone
    harga 150 ribu
    Type E
    . Brand new for Apple iPhone
    . The Slim-Fit case provides complete protection while allowing you to quickly remove your iPhone so you catch that important phone call.
    . Material: Leather
    . Protect Your Phone And Avoid Scratches
    10. INCIPIO GAMING 1337 SILICONE CASE SKIN iPHONE 3G 3GS S
    Harga 150 ribu
  5. #5
    Lightbulb charger IPOD SHUFFLE 3RD
    Quote Originally Posted by matsubi_one View Post
    All Brother, mau nitip lagi jual
    1. 100% Original Earphone Headphone With Mic for Apple iPhone
    masih dalam seal dan Box
    minta harga Rp.190.000/pc sudah termasuk onkir
    Description:
    Excellent sound quality and super clear sound..
    Color: White
    Bulk Package.
    2. 100% Brand new original iPod earphone.
    new 100% boxnya nggak ada, jadi bungkusnya hanya di balut plastik, seperti paketnya iphone/ipod
    harga bersahabat Rp.150.000 saja, sudah termasuk ongkir seluruh Indonesia..:w00t:
    [/IMG]
    Lightweight & Stylish design & Low noise
    Superior comfort and fit with soft in-ear cushion design
    Enhanced sound quality, outstanding bass and treble clarity
    Greater isolation from exterior ambient noise
    Exactly the same as the original one if not better.
    100% Brand New.
    Compatibility:
    iPod nano 1st generation
    iPod nano 2nd generation
    iPod nano 3rd
    ipod nano 4th
    iPod with video
    iPod classic
    iPod touch
    iPhone or iPhone 3G
    3. [COLOR="Blue"]Original USB Power Adapter Charger ipod iphone 3G S 3GS[/COLOR
    100% original Apple
    Tanpa box, colokan gepeng
    harga rp.150 ribu rupiah termasuk ongkir
    iPod 5th generation (video)
    iPod classic
    iPod nano 2nd generation (aluminum)
    iPod nano 3rd generation (video)
    iPod shuffle 2nd generation
    iPod touch 1st generation
    iPhone
    iPhone 3G
    iPhone 3GS
    klo charger IPOD SHUFFLE 3RD ada gak bos,pm yah thx
  6. #6
    Join Date
    Feb 2009
    Location
    jakarta barat,-6.186031, 106.807643
    Posts
    1,448
    Default
    bro yg carger itu bisa g buat iphoe 2g?????
    i  my iphone
  7. #7
    Default
    11. AGF LEATHER HOLSTER CASE CLIP FOR APPLE iPHONE 3G S 3G
    Harga 200 ribu
    official price US$29.99
    http://www.agfindings.com/products/i...-lined-holster
    12. OOTTERBOX DEFENDER WHITE BLACK CASE APPLE iPHONE 3G 3GS
    Harga 300ribu (tanpa holdster)
    350ribu (dengan Holdster)
    Official price US$50
    check official site http://www.otterbox.com/iphone-cases...defender-case/
    13. Marware Leather CEO GLIDE for 3G iPhone-Black
    Bulk package
    harga Rp. 175 ribu
    retail Price di USA $24.99
    cek marware site
    http://www.marware.com/products/iPho...4Pa38Ta38Qahv0
    untuk review kunjungi:
    http://www.iphoneincanada.ca/iphone-...one-3g-review/
    15. Original Incipio Eco Case for iphone 3G 3GS
    harga Rp. 150 ribu
    website
    http://www.myincipio.com/c=AfL9G6LCd...ne-3G-3GS.html
    The ECO|case by Incipio is our Earth First approach, constructed using environmentally friendly materials. The case is a simple yet stylish single piece design which protects the iPhone 3G while maintaining a slim profile.
    Features
    Earth first approach, using environmentally friendly materials
    Single piece minimalist design providing high style and high function
    Side openings allow easy pull access to your iPhone
    Protects device while maintaining a slim profile
    Soft lining cleans and protects screen
    Compatibility
    iPhone,
    iPod touch
    iPhone 3G
    iPhone 3GS
    16. Leather Case Keychain for iPod Shuffle 3rd Gen
    harga 40 ribu
    This Premium Design Hard Case / Cover is sure to make your 2nd Generation iPod Touch even more sharp looking. Protect your Apple in style with this snap-on 2 piece case / cover. It is durable, thin and lightweight. The fit is unbelievably perfect.
  8. #8
    Default
    17. Clear Crystal Case for iPod Shuffle 3rd Gen
    Harga Rp. 30 ribu
    100% Brand New Crystal Case
    Perfect fit for 3rd generation iPod Shuffle
    Pre-cut openings for earphone
    Protect your iPod Shuffle against scratches,
    dust and fingerprints
    18. White SOFT Crystal Gel Case FOR Apple iPhone 3GS 3G
    bonus : clear screen protector for Apple iphone 3G, 3Gs
    harga 150 ribu
    Features
    - 100% Brand new faceplate case is molded to a perfect-fit for your Phone.
    Full body protection faceplate case covers the front, back, and side of the Phone
    - Smart, Fashionable design with total access to all functions and buttons without removing your Phone from the hard case.
    19 IPHONE 3G S CASEMATE 3 PACK SCREEN PROTECTION KIT
    harga Rp. 100 ribu
    isi 3 lembar screen protector At&t Original IPHONE 3G S CASEMATE 3 PACK SCREEN PROTECTION KIT
    19.B IPHONE 3G BLACK LEATHER SHELL EASYDOCK 8GB 16GB 32G (Griffin Elan Form)
    harga 175 rb
    bulk package
    official price $29
    http://www.griffintechnology.com/products/elanform3g#
    19 D.Griffin Elan Holster Full-Coverage Leather Case for iPhone
    Harga Rp 175 ribu
    retile price $30
    http://www.griffintechnology.com/products/elanholster
    Keep your iPhone safe, under wraps, but close at hand.
    Elan Holster carries your iPhone snug in an embossed black leather shell with a no-scratch lining.
  9. #9
    Default
    20. FM TRANSMITTER+ CAR CHARGER+ HOLDER FOR IPOD IPHONE 3GS
    Harga 400 ribu
    Product Specifications: 100% brand new
    iPhone Hands-free supports talking through car speaker system
    Use any FM station From 88.1 - 107.9MHz to bring you the perfect high quality music from your iPhone / iPod
    Standard USB-A (5V, 1A) output socket provides the charging for Mobile Phone, GPS and other devices
    The flexible goose-pipe makes it convenient to find the best position for your device. It is compatible with every car in the world. Goose-pipe with rotation prevention design keeps the iPhone or any other device steady & firm in its position
    Using a flexible clamp, the holder keeps your iPhone/device in place. Removable stoppers prevent the device from being dropped. High quality silicon gel on the back & side protect your device from being damaged
    Suitable for iPhone / All iPod / All MP3 / All cars
    21. FM Transmitter+Car Charger for iPod Touc iPhone 3G 3GS
    Harga 150 Ribu
    Discription:
    1>The easiest way to broadcast your music while charging your iPod MP3 player
    2>Transmits stereo quality sound from your portable music player to your car FM radio.
    3>Frequency range: 88.1 - 107.9 MHz
    4>Powered by vehicle cigarette lighter adapter
    5>LCD display with blue background lighting.
    6>Frequency range: 88.1 - 107.9 MHz/Step
    Compatible With All Apple product
    24. 1900 mAh External Backup Battery Charger for iPhone 2G 3G iPod
    harga 175 rb
    include onkir
    Description:
    Light-weight, super-slim design to carry with your iPhone or iPod Conveniently charged via any USB ports
    High-capacity, rechargeable lithium-ion battery
    LED indicator for battery power level
    No memory effect, Li-ion battery built-in
    Specifications:
    Battery Type: Lithium-ion battery
    Capacity: 1900MAH
    Rated input: 5V 800mA
    Rated Output: 5V 500mA max
    Charge time: Around 4 hours
    Dimension: 67x62x15 (mm)
    Color: Black
    Compatible with:
    iPhone 3G 8GB/16GB
    iPhone 4GB 8GB 16GB
    iPod Touch
    iPod Nano
    iPod Classic
    iPod Video
    25A. External battery case for iphone 3G 3GS w/ camera flash
    Harga 450 rb
    uNu Camera Flash Power Case
    Get the most out of your iPhone 3G or 3Gs with the assistance from uNu Camera Flash Power Case. This innovative power case is considerably designed to make up all the weaknesses of iPhone 3G/3Gs which are:
    Small Battery Capacity
    Non-resistance to shock and scratches
    No Built-in Camera Flash
    Feature Highlights
    Super Bright Camera Flash:
    Press and hold the LED button to enable the CAMERA FLASH without any hustle, you will never worry about taking photos at night.
    Built-in battery:
    The built-in 1300mAh battery adds extra 8 hours talking time to your iPhone.
    Never Lose connection with friends
    Protection:
    This Durable case offers a full body protection against any shock and scratches.
    Anti-Slippery:
    Black Matte Finish will not only make you hold you iphone stable with ease, but also offers a perfect feel while it is in hand.
    LED Indicator:
    Our “UNU” logo 3-LED indicator will let you know how much power left, whenever you press the button.
    Smart Battery Switch:
    The Smart Switch will help to prevent continuous charging, and let you decide whenever you want to charge the iPhone.
    Smart Sync Function:
    The Micro USB charging port will also support iPhone Synchronization with PC or MACs. There is no need to take of cases when connecting to the computer.
    Super Light Weight:
    The 1.94 oz SUPER LIGHT weight will definitely beat all the competitors in the market.
    Item Specification w/ comparison to Major Brand Products:
  10. #10
    Default
    25.B External Battery Charger 5000mah for iPhone iPad 3GS
    Harga 475 ribu
    Description
    USB-Power-Station-5000mah
    Hit the centre button to charge and press it again stop charging
    Features:
    Wide compatible
    Double USB output
    Powerful with long operation time
    Partable and convenivent
    High efficiency of power conversion
    Electricity-saving function
    User friendly
    Long Cycle life
    Rapid charge
    Campatibility: Cell phone, iphone, ipod,all digital devices charged via USB port
    26 A. GRIFFIN PowerJolt Auto Charger/Adapter iPod-Iphone 9749-PJBLK
    Brand New factory seal
    Harga 225 ribu
    26.B Griffin iTrip Auto Universal FM transmitter 4 iphone
    New tanpa retail Box
    Harga 200 ribu
    Bisa untuk charger iphone/ipod (ada slot USB chargernya) serta untuk FM transmitter ipod, iphone, dan Mp3 device
    26.C griffin power jolt SE car charger for all iphone ipod
    Brand new tanpa retail Box
    harga Rp. 200 ribu
Similar Threads
  1. Jual Battery ibook 12"
    By stevensmac in forum SJB Umum
    Last Post: 26-07-2006, 15:06
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
